not slave, not master, bleeding?
Eclipse90GSX
149
Oct 13, 2002
Arlington, Texas
well, what can it be? my master and my slave is not leaking cause its brand new...but my clutch is slipping, chatters then i punch the gas, and its hard to get into gear? i guess ill bleed the system again and put some more oil into the tranny, but my question is, if the tranny is dry would it mean that the gears are harder to get into? or is it clutch related? no grinding whatsoever tho.
problem is we spilled coolant on the clutch disk, that might be causing this...dang, anyone got any ideas?
Are you motor mounts GOOD? bec what happens if the motor mounts are going bad? the motor moves out of place? and you will get problems with your Clutch! i just put in a ACT 2100 and it was hella hard! at first but then my bad motor mount started getting worse and the clutch is softer and someimtes slips? when i rev high rpms! but check that if not ? did you say? you check your Clutch master cyl? and if its not that? then i am not sure prob your clutch is going bad or somethign? well good luck!
