normal vac and afr at idle???
boost69
104
May 20, 2010
bristol, Pennsylvania
hey guys i am a little concerned about my car it has been reading some times 15 in vac at idle as well as some times the afr at idle is in the 17s and 18s, it only is like that some times and when its liek that it seems to run a tad bit rough around 700-750 rpms but then some times it will read about 17=18 in vac and afr of low 16's any input would be greatly helpful , as well as in a WOT my afr will read low 10s any thing on that would help too
thanx
guys
well according to your mods in your profile, use your safc to richen up the idle a bit. For the fluctuating vacuum, check your lines and see if you have any pinches or sharp bends in it. I know with the two different boost gauges I had, my autometer would go from 15-16 on a cold start up, but warm it would be 19. When i put my prosport in, it stayed at a constant 19. at WOT, i would pull some fuel away. do some 3rd gear pulls and get that afr up. i have mine between 11.1 and 11.8
Check to see if you have any vaccum leaks. Your vaccum at idle should be around -18 to -20. Your AFR's should bounce around 14.7, maybe like from 14.2 - 15.6 or something
well i have been reading about the lean idle and i read that it shouldnt cause a problem , the main thing to worry about is the afr at wot and it reads in the 10s, around a 10.8 which is a little rich but i am fine with that because that little richness shouldnt effect anything correct? let me know if i am incorrect about any of this , i wouldnt wanna mess somthing up LOL and im pretty sure my vac lines are good i dont get the weird vac, problem what performance wise would that have an effect on?
thanx
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
