no VAC at idle!
AWDTireSmokeTsi
140
Sep 7, 2003
Terre Haute, Indiana
I have a 90 Eagle Talon Tsi. I just finished up putting a (used) head on, new timing belt, water pump, head gasket etc.
It starts right up, idles fine around 1000k rpm. My boost gauge reads 0 at idle, and around -4 if i rev it to 1800-2000k. Sounds decent, does have a little bit of a miss.
-Ive boost leak tested it. None besides a tiny one at the throttle body (doesnt leak til 20 psi, takes about 6 minutes for system to bleed down to zero).
-Ive tested the gauge in another vehicle, works fine. Ive also tried different vaccum lines, and tapping from other vaccum sources. I have no emmisions, ive tapped ic pipe, fpr, throttle body...doesnt make a difference.
-Ive checked cam timing. Dead on.
I have a small exhaust leak at the manifold to head (broken stud).Also running an open downpipe. I wouldnt think this would cause this problem.
I might be thinkin valve seals are junk or something along those lines. I am going to compression test it after work tonight, but other than that, Im runnin out of ideas. I may take it out and actually try to hit boost and see what it does if compression test checks out. Anyone?
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
