No Vac at Idle.
Cody D
93
May 26, 2004
Olds, AB, Canada
A normal DSM is supposed to be approximately -18hg at idle right?
Mine reads 0hg, and when I give it some gas it does go into vaccum and with my boost controller set normal it shows 8 or 9 psi. It's a brand new boost gauge, my old one showed the same thing.
Anybody tell me what I broke?
It sounds like you either have a vacuum leak or you have your boost gauge tapped into the wrong vacuum line.
If you are not having any drivability issues then I would lean towards the tapped into the wrong vacuum line explanation.
There is a line that runs from the intake manifold to the fuel pressure solenoid to the fuel pressure regulator. Try moving your gauge source to the vacuum line running between the intake manifold and the fuel pressure solenoid.
Let us know how it turns out :thumb:
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
