Normal block casting? (thrust bearing)
SpankyStokes
120
77
Oct 15, 2019
San Antonio, Texas
This part of the block has got me iffy as it seems very thin. I saw some pics of another block but can’t tell if it’s normal. Surface is where the thrust bearing sits.
It doesn't need much, just a lip to prevent it from moving. The crank will sandwich it in there so it's not going anywhere. The only thing I would be worried about is if the actual thrust surface was worn into by the crank previously making the whole block junk.
