none of my lights will turn on
96_gsx
Oct 13, 2013
Fargo, North Dakota
I have just purchased a 96 gsx and none of the lights will turn on. It is not blowing fuses and was told by the previous owner that the bulbs are good. Is it possible that it is a grounding error? But if its all the lights including the blinkers and dash lights is it more serious?
speak with the previous owner and see if anything happened that might have caused it, like him installing something in the car or anything like that.
well there were LED lights installed under the dash on the passenger and driver side. But I don't know if they'd be tied in with the not working headlights because they work and don't need a switch to turn them on
nothing blown, used a multimeter and it said no power was making it to the tail lights or head lights. I think it might be in the switch but since the brake lights are out to what could it be?
I had an old pick up that the fse box itself was going bad and caused my lights not to work. just a thought.
I would just change the fuses dude.. Even if they don't look bad - at least this way you will be able to tell if it's an internal issue
If it's internal - could be the box itself - could be within the switch itself - this is to say if they tapped that wire for the "LED" lights <.<
Question is though - how much draw is the inside getting for power? Because if there's more power required then the size of your battery needed - you may need a separate power source for the interior lighting
12 volts, but the the blinkers don't even say they are working on the gauges so I think it may be the switches
    • Sdcryan1
