2G Non-cruise control cable
gst-turbo
677
59
Nov 7, 2012
Petaluma, California
Dose any one know where I can find one, every place I have looked are not in stock I been looking for one for a while?
2g cable has a different bend in it at the firewall connection. It is bent in a different direction. "SOME" have had luck in re-bending it and "SOME" have kinked theirs trying.
also you can easily make one, ebay has kits for them, you just need a tool to "close" the ends cuz those cables are universal, I've made a few
No need to re-bend it, you just mount it 180 degrees out, pointing down and loop the cable around.
Thanks Jason, I knew they would bolt up but I don't have a 2g to test them on. I can see the picture, as you say pointing down and you're right, it doesn't care what direction it's pointed, as long as it ends up at the TB :thumb:
Marty
Can confirm, it works. I just did it tonight after seeing @jdnxc picture. It does create a few tight radius bends which increases resistance on the cable, and the outlet by the pedal is at a non optimal angle as it points away from the pedal. That can be rectified by a bit of careful bending under the dash but you are more likely to crush it so if I were to do it again I would bend before mounting. It will end up wearing through the plastic liner quicker.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
