Non Blowthrew pipe reused?
92Talon251
220
Sep 26, 2003
Fayetteville, North Carolina
Well a while back I indirectly damaged the Upper Honey Comb on my 1G MAFS by droping a screwdriver on it. Well bacicly it bent alot of the honeycombs I tryed to fix them by taking phillps head screwdriver and remaking the bent honeycombs to circles by turning the screwdriver 360 degrees to make a circle. With the idle problems I have been having I just thought I would use a GM MAFS. Recently I installed the dejontool upper intercooler pipe without the GM MAFS blowthrew is there anyway I can modify the non blowthrew design to use a GM MAFS?
:talon:
Do you know how much to cut off each end ?? Also no other modifaction is needed ?
:talon:
:talon:
You don't cut the ends. Cut it in the middle where you want the MAF to go.
