Resolved 1G Can stock head bolts be reused?
phenyxTA
Jan 29, 2004
St. Louis, Missouri
Can they be reused or are they torque to yield? What gaskets have to be replaced during a head install other than the head gasket? Thanks.
Solution
6-bolt head bolts can be re-used.
7-bolt head bolts cannot.
You could replace the valve cover gasket and exhaust manifold gaskets, not much else that should need to be messed with in the gasket department though.
Solution
