GooeyGus
- 459
- 1
- Sep 23, 2009
Marysville,
Washington
Ok, my lifters are SOOOO noisy that it has started to effect my fuel economy. I can feel the ECU pulling timing like crazy because it is sensing the noisy lifters as knock. Other than the noisy lifters the car is running great.
BUT the lack of timing is really starting to put a damper on my fuel economy. I'm losing up to 2-5mpg because of this.
Now, I know the solution is obviously to change the lifters. I plan on ordering the 3g lifters next weekend and swap them in the following weekend.
Is there ANYTHING I can do in the mean time to make things a bit better? I just changed the oil about 200 miles ago and added some lucas oil stabilizer, but it seems like it didn't help much. If anything it seemed to tick a bit less with the old oil in there.
Also, my ECU recently died and it seems like this ECU is doing a much "better" job of sensing knock and retarding timing.
Anyway, if anyone has some tricks to get me through the next two weeks it would be greatly appreciated. This is just my daily driver right now, it might see WOT like once every few weeks.
Thanks!
Thanks!
