nobody can cut my flywheel
EVO9_Inside
75
Aug 6, 2011
akron, Ohio
Im trying to get my fidanza alum flywheel step height checked and cut but none of the machine shops i take it to will touch it. Does anybody know what kind of lathe i need to find to get this cut, or what the step height of a new fidanza wheel is?
Right from Fidanza's website... Amazing what Google can do, eh?
WHAT STEP HEIGHT IS MY NEW FIDANZA FLYWHEEL MADE WITH? – We design our flywheels using the factory step height. The only exception would be custom units or those intended for multi disc clutches.
As for your other question, most shops (That I know of) use a machine specifically for flywheels. I doubt you're going to find one of those on Craigslist...
Why would you need to cut a Fidanza or change the step height? Replacement friction surfaces are available for purchase, and the step height remains unchanged from the factory spec.
Exactly: replace the friction disc. Its just held in by a bunch of philips screws iirc.
I test everything that goes into my car, why do a job twice when i can be done once? Its a new friction, used disk, but since the clutch the previous owner put in didnt hold shit for torque id like to be certain to outrule a flywheel failure.
I still cant find a proper spec online, but i guess if "factory spec" counts as a numerical 100% of accuracy and outrules any sort of quality error ill trust your judgements.
call south bend clutch in Indiana 18009884345 u have to ship it if u want it done right im afraid great peace of mind
nick will take care of you
tell him tommy from Schreiber performance sent you.
also .609 to .610 is what u want.
make sure the flywheel has no deep cracks or broken pins or stripped holes.
I will only let southbend clutch or roadrace touch my flywheels.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
