no start clicking noise under dash
SLOWKID
30
Jan 13, 2006
Altoona, Pennsylvania
Got in my car and all my lights start going on and off and I can here a clicking noise under dash near brake pedal so I start the car no problem and turned on my lights they stopped going on and off but I still hear the clicking sound kind of like a turn signal sound turn lights off they start acting up again so I go to the store come out and car wont start I have lights and everything still here the clicking and lights still acting up but no start I got a jump from my dad still nothing so I got him to push my car so we could pop the clutch it worked took three times but it started got home turned it off and now a no start again any help would be nice thank you
I had a similar scenario without the lights going on/off in my 93 tsi . Turned out to be my computer (ecu) had some corrosion on one of the vertical boards. If no other solutions come to you view a picture of inside a good ecu and a bad ecu with corrosion and open yours and take a peek and see if yours looks the same. Don't know where the ecu is located on a 2g but its behind the radio on a 1g. It was pretty easy for me to check. Hope this helps
Well the clicking noises are coming from a little black box about 3 inchs squared under my dash far left near clutch pedal and when I try to turn it over I can feel it clicking even more inside the box I think its some kind of relay not sure but car still wont start the other day my locks started to act up but it was on for about 15 sec
YouTube - dsm problem.avi
This is what was happening to me. When I turned the key to the on position it would do this. The clicking was coming from my fuel pump relay. I didn't touch the key but once to put it to the on position in this video. This did not effect my lights or locks, my symptoms were no starts and sometimes shut off while driving, but would start right back up but Would not start until this clicking stuff stopped. sometimes it would last a long time. Sometimes I wouldn't see the symptoms for a month. Hope this helps.
OP. please learn to use the symbols in the brackets [. , ! ; : ' " ]. May not help you. But it wil help the other folks.
