2G no start after head change?
kenuwine4g63
601
50
May 26, 2009
Charlotte, North Carolina
Ok guy i searched and searched and cannot find/figure out the problem. I came to the conclusion that i have no spark..AT ALL..I just put another head on the car due to my last one bending valves. I have compression but no spark. I have a volt tester that messures all resistance and voltage..When i look at how to test the coil pack primary resistance do i suppose to test it at the plug or the connecter itself..the secondary is reading 13.13, and 13.5 so the coil pack is good?? But when i do the primary i get readings like .1 to .5...Where should i have my meters turned to. I know the horseshoe sign is for resistance, but it gives me values(20m, 2m, 200k, 20k, 2k, 200) which one do i turn the nob to..I also unpluged the transitor and tried starting the car and it makes the same exact sound as if i had it plug up..I switch transistors and still no spark..I need help havnt driven my car in 3 months and its my DD.
There was only clearance on one side of the valve seat. If this would have been a lifter issue the clearance would have been equal all the way around.
