GSTdude06
- 481
- 11
- Oct 29, 2005
Mesquite,
Texas
I went ahead and did the 6bolt swap when my 7bolt stopped working. Ive replaced nearly everything except the ECU, but for some reason i'm not getting spark or fuel. Ive searched thru this whole website number of times checking everything yall say to check : fuel pump, mpi relay, fuses, CAS, coils, everything. Nothing seems to change anything.
Ive jumped my fuel pump, I get as much fuel pressure as I need.
Ive test lighted the injectors and spark neither fire.
All plugs and sensors are hooked up ive triple checked that.
My CAS is wired blk to red red to blk.... another member said that was the correct way, the other wires are hooked up 1 to a different plug
any ideas?
any ideas?
