No spark, no fuel
nicknorth11
663
7
Feb 9, 2005
Grand Blanc, Michigan
A friend of mine is having problems with his 95 gs-t. He was driving down the road and it just shot off. It will turn over, but will not start back up. He tested it and it is getting no spark or fuel. He has tested the ecu, cas and engine fuse. He is going to test the crank sensor tomorrow. Is there anything that he could be forgetting that would cause both of these problems to occur at the same time?
Thank you.
Have you checked to see if the timing belt is still there? If it snapped the cam position sensor won't read and may result in no fuel/fire, among other bad things.
