1G No spark issue
snoopDSM
Sep 24, 2007
Columbia, South Carolina
Im having a problem with my 1990 Eagle Talon TSI. Its getting no spark i have been checking the coil pack and not getting any consistent readings so i think that could be one but just in case i wanted to know how do i check the CAS. Also the car has a new motoguys rebuilt ecu in it. The car is getting fuel but when starting the car the CEL does not display is that correct?
when you turn the ignition key to ON the CEL should come up for appox. 5 seconds before shutting off. if the CEL isn't lighting up at all then its either a burnt bulb :rolleyes: or your "rebuilt" ECU isn't communicating properly...
i wouldn't worry about testing the CAS until you get a known good ECU in there.
:dsm:
If the fuel pump turns on when your car cranks, your CAS will be fine. If you have a CEL on, pull the codes and reference your FSM to find out whats broken.
You can also pull your CAS out, turn the key on, spin the CAS by hand and see if your plugs fire.
