2G No pressure in clutch pedal
Talon Cooke
32
4
Jan 27, 2020
Winnipeg, MB, Canada
did a pull yesterday at higher boost than usual, (16 g turbo) around 18 psi, went to shift into 3rd after hitting close to redline , and i missed 3rd. I couldnt get it in gear for whatever reason (3rd gear is a little crunchy in my car) so i coasted a little ways then revved back up and tried putting it in again, this time gently. got it into 3rd and continued cruising as usual. after this attempt of shifting that hard going that fast into 3rd the pedal now felt pretty loosey goosey. The rest of my cruise i noticed the pedal feeling super loose, with very little spring action. I turned it off to get gas, started it again and the pedal felt normal again. Parked it for the night. This morning i went to start, put the clutch in and it had no resistance at all, stayed pressed down to the floor and didnt return. Clutch still disengages as i can still start the car. But theres no pressure at all. Im guessing the master cylinder? but im not sure, i didnt notice any visible leaks underneath. Just looking for some opinions before i replace the master cylinder. Thanks boys.
Glad you were HOME!!!
