Clutch has no pressure
Bankos66
Sep 7, 2012
Northampton, Pennsylvania
Before I get flamed for "not using the search bar" I looked and just want a definite answer.
The car I have is a 95 Eclipse RS. I was driving it fine in the morning and was shifting perfect. Then when I went out about 6 hours later, the clutch had no resistance or pressure at all and it would not go into any gear. I have read that this could be the master or slave cylinder. Any help would be appreciated cause I don't think its the clutch and just need advice. Thanks in advance.
The reservoir was empty so I tried to add some fluid and its staying in there. I checked inside above the pedal and felt the line there and it had fluid on it. Does that mean it could be my master cylinder?
If the fluid is leaking inside near the pedal it's most likely your master cylinder. I just replaced mine a few months ago it wasn't that hard. Just make sure you follow the proper clutch adjustment procedure afterwards and bleed the system good after installing.
