2G No power to fuel pump 95 tsi on black box
Rajin
226
Jan 22, 2010
Cookeville, Tennessee
Ok. The only things I have left to do. Aside from interior repairs is replace my clutch slave and line and get my fuel pump to power on. Issue is, I get no power to my fuel pump, it worked prior to arrival at my current destination and now nothing. It's the last thing holding me back from getting it running so I can keep it.
Black box AWD ecu, no other issues known
Fire the fuel pump with the check connector. See if there is power at the pump. If not move to relay. I'd start with checking fuses.
If you get power at the pump but you have no fuel, pump is probably dead. Has this car been sitting?
if you have link pull ou the back seat and take a phillps and unscrew the plate to the pump behind the passenger seat, , turn the the pump on using link and see if you are getting power to the pump using a volt meter, the blue with red strip is positive, if no, check you relay for power and make sure all the connections are clean. search this site under no start, and there are instructions on how to test the relay. You should be able to narow it down to pump, relay or connection failiur. dont for get to check your ground wire for continuity
Fire the check connector and then check voltage at the pump. If you have voltage put a line on the fpr return and see if fuel comes out. Listen for the pump also if you have voltage. If you have voltage but dont hear pump the problem is right there. If you have voltage, hear pump but no fuel the pump install was done incorrectly. if you have no voltage you have a problem in the circuit. Either a fuse, relay or wiring.
    • george bromwell
    • pma1123
    • Sdcryan1
