ryan95eclipse
- 123
- 0
- Jul 13, 2010
lorain,
Ohio
Ok guys i could really use some help here. i took a change on this 95 eclipse gs with the engine built up. guy said its bored .40 over with eagle rods n other good shit blah blah blah. i can tell a difference from driving my other eclipses so i believe its true. but here my problem. i bought to car not even hearing it turn over. he said it was rebuilt at 89k and it now has 94,539 miles. i got it running. changed a shit ton of parts. and noticed it over heating. it ran so hot you couldnt touch the hood. the oil light would flicker at idle and when i would downshift or come to a stop. but when rev'd it would quickly go away. i checked the psi with a gauge and it read 0oilpsi. Stripped it down. changed the belts water pump and oil pump. got it back together with what the timing was previously set at. got it fired up after a few turn overs. and it read 6psi at idle but after a few minutes it would drop to 0 and get hot as the sun again. i shut it off and said #### it after working on it for 10+ hours. started it the next day and it would barely start. quit cranking over. back fired ran like pure shit. got it running again and still getting hot. i have no idea why its getting hot. radiator? headgasket? but once you start it cold and rev it up real quick it barely makes a rattle at about 2krpm+ the more you rev it up the louder it gets. and the hotter it gets the louder it gets. can anyone please help me? i wont be able to check this much but i will when i can. please text me with any possible answers. maybe timingadvanced or retarded? please help 440 654 0344 my name is ryan
I also read a few other places that the timing belt tensioner bearing could make a rattle if it moves back and forth and if the belt is loose but the belt is tight. im about to do a compression test and see what that says so i know a little more about if its a headgasket or such. i have seen a lot about the lifters could be screaming. it could be valves and much more. i rather adjust little shit then rebuild. anyone ever heard of such things making an engine over heat?
