no oil presure new motor HELP !!!
spoooling4g63
Jan 18, 2010
las Vegas, Nevada
HI guys , i got a lil problem getting the oil pressure in my newly build 4g63 , i pulled the oil pump gears out so i can clean everything , i put tham back together and back in the motor , now when i try to build oil pressure there is none ( before i try to crank the car my oil level is perfect but after i crank the car the oil level rises ) is there any way i put the gears in wrong way ?? it seems like the pump is not sucking the oil , it looks like pump is actually pushing air into the oil pan ,,, is this evan possible ??? any hints will help thanks
hey thanks you guys ,that did it , if any of you ever come to vegas just let me know i"ll pay for some lap dances :)
thanks again guys
    • Sdcryan1
