Justin DuBois
DSM Wiseman
- 3,341
- 3,312
- Aug 15, 2019
Oakland,
California
I've been tryng to get my idle down to my 800rpm target, but it just barely sits there when everything is good an warmed up. The ISC shows 0 most of the time, but if I put some load on with the AC, then it jumps up and has better control.
I've boost leak tested, and there is nothing leaking.
The BISS is all the way closed, so there is no more room to adjust there
I'm still using a stock 1G FIAV plumbed with coolant lines, and it does the bulk of the work. On first start start, Idle is 2000k, then as the coolant temps warm up, it drops to 1000, and very very slowly drops to 900.
Any suggestions?
Any suggestions?
