2G No fuel to cylinders 2 or 3
Noahrieke
67
7
Mar 17, 2020
Billings, Montana
Hey everyone! I pulled my engine as a winter project just replacing head gasket and others but now I have everything back together. Got it running and it ran like absolute garbage. After a long while of trying to figure it out I finally pulled my plugs and saw that inside cylinder 2-3 were completely dry and the spark plugs had no fuel on them. So then i realized the car was running on only 2 cylinders. I’m going to clean the injectors and also check to see the voltage on the injector plugs. Any other ideas of what I should check/ what may be causing this?
Thanks-Noah
