No fuel pump power
ThEDrEaMEnDeR
711
Apr 3, 2010
beaumont, Connecticut
Hey guys,
Im getting no power to my fuel pump.
I haven changed any wiring and I cant figure out why its no getting power.
I cant find any relays or fuses to it.
Any help would be appreciated.
Mike
Have you connected a voltage meter to the power wire on the pump harness? Then there's a fuel pump power jumper wire on your fire wall to see if it turns on. It could narrow down your search. Then again the pump could have just taken a dive on you.
This is what happened to me after I got a ecu from a board memeber, I would start the car, it would run and die in 2 secs, so I tapped the MPI 12v wire off the ecu to the FP Relay wire on the ecu so that it sees 12v. works like a charm. easiest way to get it to work.
-shane
