2G No crank
TOM M
Mar 3, 2024
BURLINGTON, ON, Canada
1995 gsx will not crank just changed starter so it not that the starter relay clicks I’ve tried everything and can’t get it to crank cen anyone halp
Check the main power wire from the battery and the GROUND wire from the battery that go to the starter. The ONLY other wire is a momentary 12v wire from the ignition switch. It is the small female blade connector on the starter. Make sure it is hooked up. That is what activates the starter. If all is good, hook a random wire to the blade terminal and then touch the other end to the + on the battery. That should activate the starter, so make sure the car is in neutral or park.
Marty
Marty
I tried that and the car started but idk why there’s no power going to the tiny solenoid wire and in case you’re wondering I did forgot the car win in gear
