no compression !!!!!!
domothegreat18
87
Aug 24, 2009
Napanoch, New York
hey whats up i started my talon once after i had the valves replaced drove the car once parked it came to start it again and nothing so i change everything ecu pt coil and etc
so upon of my head i seen that my rockers were lose on my intake cam . i can take the rocker out and put it back in without a problem i know this iisn't good and also my block just seized up from me trying to start the car so how would i fix this head problem the head is fully ported and all internals are stock
You know those nice new valves you just installed?
Well, I'm pretty sure you just bent 8 of them.
x2 You have bent valves. Typical symptom when you have pretty badly bent valves.
I didn't i do th timing for the motor and thanks alot guys i guess i have to rebuild now
Im going to pull the head tomorrow morning after work i will post pics
well the result wasnt pretty at all
That looks... pretty.
Had the same thing happen... But I bought the car and the PO didn't know what happened. May want to throw new pistons in now as well.
