no compression
DearDoger
123
Jan 26, 2008
Battle Ground, Washington
I replaced my clutch tried to start the car and it turned over and over but didnt fire. I took the spark plugs out they smelled like gas so i figured i flooded it then i turned the motor over to kick out all the extra gas but nothing. it just turned over and over. the motor ran just fine before i replaced the clutch. So any ideas.
Like Mr. Peepers said, check to see if you have spark, if you do then check to see if theres any boost/vacuum leaks, you may have bumped something loose or forgot to hook something back up when installing the clutch.
