no compression
95tsi4g63
Mar 18, 2012
newport, North Carolina
just rebuilt my motor and it wont start, got a compression tester today no compression. did i bend some valves?
You should ALWAYS, ALWAYS, turn your motor over by hand after Doing anything with the timing. Could have saved yourself some trouble. You may have even broke a valve which could be tearing up your cylinder walls everytime u crank it. No compression on any of the cylinders?
trust me i had the timing 100% idk if it just jumped or what i marked the timing with a grease marker and rotated the motor and it lined up.
no compression at all
I have done that also 1 time before i had all marks lined up, everything correct and turned by hand had compression during priming of oil, the second i actually started it BOOM jumped time, bye bye $300 valve job.
Did you put the timing plate on the crank on backwards? Seen that over 5 times and have done it once, But caught it because I spun the motor by HAND before starting it. That will bend the valves
found my problem. the timing marks were wright. one of the dowel pins were not. i feel like an idiot the whole reason for the rebuild was because the car jumped timing and dropping a valve. anothere 400 down the drain.
is there anyway by chance it didnt bend a valve?
it runs!!!!!!!!!!!!!!!!!!!!!!!!!!! thanks. im guessing the valves are fine or? only ran it for a second
oooh, damn bro. im feelin your pain. better luck when it goes back together next time. you could be on the road in 2 weeks and its not alot of money. i know it sucks but its not a 2000 dollar f up.
