no clutch pedal pressure
cubedmayhem
94
Sep 7, 2003
kirtland,
Whats up some help would be sweet. The issue is that my spyder was running great and parked it over night and the next morning the clutch went straight to the floor and can even put it in any gear with the car on . If i try to jam it in gear it will stat to move in that direction. My first thought was the linkage but nothing was loose or in the way. No warning of any failure was noticed but i just hit 81k so i would think the clutch is on its way out. Before i fork out the money for a flywheel and clutch, etc is there anything else it might be? PLEASE HELP GUYS!!!!!!
before throwing gdown on a new clutch check the master and slave cylinders. to check the master just look by your clutch pedal and check for fluids. the slave is under the car and is pretty easy to find. either dsmtuners or the vfaq has write ups on how to change both.
if you have problems pm me i just did both of them on my car
