clutch pedal..no pressure
gijeff1805
Jan 26, 2004
conyers, Georgia
i just got a new used tranny and new OE clutch put in cause well had some problems with old tranny..but anyway i was wondering before i had tranny problems i had i guess about 89000 miles on original clutch still was good clutch no slippin or anything, and the clutch pedal had pressure to it...but now after this new clutch when i push in the clutch well the pedal has like no pressure to it, its engaging fine and everything, just there is no pressure liek it used to have with old clutch, when i press down it just goes to the floor easily...i took it and asked them if it needed to be adjusted or somethin but they said thats how the new clutch feels like..its how it supposed to be, i was wonderng well could it possubly be like a air bubble in line or somethin like when u bleed brakes, or maybe i have to adjust pedal? i dont know, or maybe he is right and the clutch is prefectly fine and well then ill just have to get used to it which will take like a day, but i just wanted to check and see if it might be somethin. thanx
Bleed your clutch. As long as everything was machined to spec and the TOB was installed you shouldn't have to adjust anything. Odds are you have air in your slave cyl.
Remove the cap from the res then open the bleeder......let the system do a gravity bleed until no air bubbles come out...then close the bleeder, fill the res, and replace the cap.
Good to go.
