no boost building.
internal or external? you can put a vacuum/boot line to it and you should be able to see it operate
I had this problem the other day and it turned out that the pin holding the wastegate arm to the compressor housing had fallen out; try visually inspecting that and making sure the pin is there.
Try taking the actuator arm off of the flapper and see if the flapper moves freely
with the compressed air and vaccum
would i just first test to see if it is opening by putting the air through, and then test if closing by hooking up a vaccum to it?
No problem, just keep in mind how they work and you'll be okay. The flapper door has to be closed to build boost. As you reach maximum boost which is dictated by the wastegate spring the wastegate will start to open the flapper door to allow the exhaust gasses to bypass the turbine wheel (exhaust wheel) to keep the turbo from overboosting. Make sense?:)
So a stuck open wastegate/flapper door can cause no boost to be made.
And a stuck closed wastegate/flapper door can cause an overboost problem.
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
