No axle bracket?
gst_man
43
Jan 11, 2010
Wichtia, Kansas
Okay, so I bought a non-running 2g (FWD Turbo) that needs a new engine. When pulling the engine I happened to notice that there was no axle bracket on the drivers side axle...I am a little confused as to how that happened, but can I just throw an axle bracket in there, or should I go ahead and replace the whole axle? Thank you for your time.
Scott Y.
2gs do not have the half shaft design they have one strait shaft.
WRONG....
FWD's use a long driverside axle.....1 long shaft...
ALL AWD's use a driverside axle and intermediate shaft....2 short shafts....
The intermediate shaft has a carrier bearing on it which either bolts to the block 95-96 models or bolts to the block and a/c bracket on 97-99 models
Right, so what I'm asking is, can I buy this carrier bearing/bracket, or should I just replace the whole axle?
Ahh I see now, I guess I can take that off my list of things to worry about, thank you for your time.
the carrier bearing and the half shafts. but i wouldnt go changing stuff around like that if its stock like it is, on my 3g i only have one long shaft.
I'm not sure if there is a difference between axles from 90 and 91-94. But all you would need is just the driverside axle and the intermeditae shaft from a 90 at the minimum....again not sure on 91+.....
Just pop your axle out pop the awd ones in voila done.....
btw I hate 90's.....the bastard child of the dsm era LOL
