intermediate axle bracket bolts HELP
Boostawdtsi7
Sep 29, 2008
Bryan, Texas
Ok I NEED HELP i have a 92 eagle talon tsi awd and i bought it as a project car last month well it is almost done but the intermediate shaft where it bolts on the the back of the engine will not line up with the bracket it is literally a hair away i have tried for 5 hours today to get in 1 bolt when i pulled it off it was not bolted on is this maybe y??? any suggestions please!!!!!
Robert
check your mounts,as well as tranny bolts to make sure they're connected, I have issues with that bolt too; it just takes me awhile and alot of screaming aimlessly under the car when i drop the bolt on my face. ha. Which way does the bracket need to go to line up? left, right, up , down?
Never ran into this problem but; is the car suported on stands to free up axle travel? Does the axle have a little travel in the trans so that it lines up? Is the A/C bracket tight, the bracket mounts to it too. Good luck.
it needs to go a lil to the right and it is really frustrating and up
yes the car is actually on 4 stands ### originally i was just going to bleed the clutch when i did this i lost my clutch went strait to the floor Thats when i found this site hoping it was the slave cylinder so i changed it and now tryin to get this last axle in place from where i took the tranny out.
use some lock washers and lock tite on those. I had two come loose and that axle fell out of the tranny. havent had the problem since.
I used to break those bolts off on the daily before i figured out what was going on. Make sure the A/C bracket is on the car, or at least space the axle carrier back about 3/4". Other than that I don't know.
ok i got it thanks for yalls help what it was was the brcket connected to the axle was pushed back closer to one of the boots thats y it was not lining up i felt retarted when i pryed it back and than it slipped on to the hole...LOL
