Ngk??
For your setup I would do NGK bpr7s gapped between .028-.032
depending on how much boost you are running NGK BPR7ES is the way to go if you are running over 16lbs other than that BPR6ES should do. i wouldn't gap them more than .028 though or you'll start breaking up at the top
ok found them going to get them tomorrow when i pick up my magstar spark wires..
