chavez408
- 1,115
- 1
- Dec 13, 2003
Bay Area,
California
what happen if you run meth in your car but in the long run you forget to refill and hit boost? Would any damages occur? Or even if you do not hit boost at all.
I'd figure the motor will go boom. Some turbocharged miatas were telling me nothing will happen if you run out of meth if your in boost.
i wanted to come in here with a smart ass comment becuase of the title of the thread, along the lines of you car may start to scratch itself alot and develop sores along with stayin up for days on end and being banned from you local walmart. But instead i learned a few things while reading my way down to the reply button.
And please dont cheap out on crappy pumps that will Fail aftertime. wich leads u to the same thing. No fluid goin in.
i rock a stg2 snow performance.
I use a progressive alky kit from Alkycontrol. This kit uses a map sensor that turns the alky on at 4psi @ low pump pressure and is @ full pressure by 12psi. I run straight meth and boost to 28psi with 0 knock on 91. Julio's kit uses Braided stainless lines and superflow pumps, low meth level indicator as well and his customer service is great.
Meth is bad for you. Don't do drugs.
Meth is the only drug that is bad for you, and coke
