theface
- 1
- May 31, 2023
edmonton,
AB, Canada
Pretty sure profile is complete.
880cc injectors, 255 rewire mod, AEM rail, FPR 43.5, Garret 60-1 turbo, built engine, 272 cams, revised lifters, upgraded dual springs, 8:2:1 bottom end, ARP bottom end, ARP top end, 110 or 120 with ARP lube, MLS HG, external 46mm WG, MBC, 3" mitsu rad, AEM series X WB, NGK bpr8s, also on SD.
I have cruise value issues, WOT I know should have but got the AFR for that down still have some adjustments to do. Cruising global adjusting makes it worse any farther than I have it. No blt base set at 5, SD tables seem to be getting out too high after going for a couple cruises and trying to rick click for combine ft adjust.
