new sway bar
baxsom
480
5
Jul 10, 2004
san antonoio, Texas
how much of an improvement would an aftermarket rear sway bar give over the stock one on my 96 gs
If youve got good tires its really hard to break loose the back anyway and I even have extra weight(subs and amp). I have pushed it hard. I think just putting in the RM rear sway bar made it more neutral to slight and I say slight oversteer. I will be putting in the front one as soon as I have a free weekend cuz last time I needed to use a torch for the stupid ass bolts :rolleyes: . The back will be really nice and the car has a much more solid feel over bumps and no rolling of the car. However, my front end feels a little loose (relatively) now which is why im putting on the front eventually.
right now it has yokohama prada spec II's on it
with eibach coilovers and the stock sway bar
my mechanic said that it would handle better with a larger sway bar
it corners on rails now so i was just wondering if it would be a noticable improvement or an unnecessary upgrade
baxsom said:
it corners on rails now...
It's hard to express how much I hate that saying. If you want something that corners on rails, get a model train set.
The main purpose of anti-sway bars is to control where weight transfer takes place; reducing body roll is secondary (and should, in fact, be controlled by the springs, instead). Your mechanic is correct: moving some weight transfer to the rear will help the handling of your car, especially given the current mods.
- Jtoby
ok maybe the "corner on rails" analogy is a little cliche guilty; hard curves are no problem but it usually drifts a little to the outside
body roll now isnt really noticable to my untrained butt and i ususally end up slightly countersteering to straighten back out
now i am by no means an excellent driver
no one has ever taken me out and actually shown me how to take a tight turn as fast as the car possibly can so if it sounds like i dont really know what i am talking about then you are correct
all i know is i want to car to hold the road and since i do not yet have the skills (practice makes habit) the car needs to compensate as much as possible
Whoa! If you already taking corners in a counter-steer drift, then the last thing you need is a new rear sway-bar. Aftermarket sway-bars are stiffer than stock.
Every now and then I really screw up and get into a counter-steer drift. But this is rare and not something that I can reproduce at will, even with RM sways and 500/450 springs. What's up with your car?
- Jtoby
i am sure it is me
the builder can drive the same corners at the same speed and never even leave his lane
i just need practice
