sway bar bushings
link doesnt work. Also the sway bar bushings just hold the bar up against the car. Do you mean the endlinks?
I am not sure what to buy, that is kinda what i am asking. Sorry.
i guess the link doesn't work after it "times out" i just searched the page.
You can get the sway bar end links at a dealer. The poly bushings can be picked up at your favorite vendor. I have an 90 awd and it does not use bushings on the front sway bar, just the end links. Pesonally I don't think it will give you any noticable difference.
so, can i just replace the bushings on my current endlink? Everything is fine, i just want a little better handling.
- Jtoby
ps. to the person who suggested that upgrading the bushings between the bar and the chassis brackets would not help ... please don't say such things
I replaced all of my bushing with poly bushings a few months ago and it made a very noticeable difference. The only problem is they are starting to squeak.
jtmcinder said:
- Jtoby
Jtoby, thanks for refuting the myths, however, do you have any suggestions for my question?
jtmcinder said:
- Jtoby
That didn't excactly read like I had intended...sorry. On my front sway bar there are no poly bushings on the end links. However there are bushings that go between the chassis and bar. I think if you are looking for a noticable difference you will need to replace both the bushings and your end links.
    • Sdcryan1
