Anyone used energy suspension sway bar bushings
92gsxbafaro
256
24
May 20, 2011
Spokane, Washington
Hey I'm wondering if anyone has used the energy suspension sway bar bracket kit? Did it help at all with handling? My sway bar bushings need to be replaced so bought the energy suspension kit and just looking for some first hand experience with those.
I was going to buy a godspeed 21mm front sway bar with bushings and 19mm rear sway bar with bushings. ( I believe the stock front is 17mm and rear is 14mm on a 2g)... if you just put the energy suspension bushings in it will help a little but not NEAR as much as a sway bar upgrade will help
I pretty much just needed to change the bushings it is making a clunking sound when i go over bumps and I've pretty much replaced every suspension part but that. did it help much with handling? i have energy suspension front control arm bushings i have yet to put on also
