New oil feed line for evo 3 doesnt fit?
bob123131
457
Dec 20, 2004
winona, Minnesota
The oil feed line that my kit with has a large male end, but the stock was a female end that had a small male end go into it. There is no way i can screw a small male into a larger one since the larger one is not threaded. I read somewhere when i was searcing that some 95-99 had a different stock oil feed line and that you could get an adapter or something from hrc, but i have not been able to find one. If anyone has any ideas or knows where i cna get one ### help my car is a daily driver and i need it bad.
the problem is that the oil feed line kits do not fit my car. This is copied off the vfaq site "Apparently, some second generation cars come with a lower hard line with a small MALE connector instead of the large female connector. In this case, HRC was kind enough to give you a small female to female brass fitting so you can join the small male connector of the new stainless oil feed line with the small male connector of the FREAK lower oil hard line. Remember, you still need to ensure you don't damage the lower oil feed line when you separate it from the factory upper hard line." This is my problem.
If you have a NAPA or Home Depot near by they should have a section of just brass fittings. You will be able to find the size there. NAPA I know has them for sure because I have had to find it for another DSMer before.
