Upgraded from 14b to B16g..now oil feed line doesnt fit! Help
FullthrottleGST
127
Sep 21, 2004
Bay Area, California
everything else fit nicely...just swapped all the stuff from the 14b to 16g. now the oil feed line on the 16g is bent slightly off of where it's suppose to connect to the head. ive tried hours and hours by trying to bend the oil feed line to make it fit, but it just wont! im really getting pissed. did anyone have a problem like this?
now..i was thinkin of either trying to swap the 14b's feed line onto the 16g..but will an upgraded braided stainelss steel one be better?
alright i just got done doing this myself so i can kinda help. On the oil feed line there is a male to femal connector in the middle of the line you have to disconnect the male from the female. It is a royal pain in the ass so i would just get the slow boy stainless steel line so you can get ride of that line all together.
if its just the bolt holes that dont line up , dremel out the holes on the tube and it will fit do each side even and dont do too much with out checking fitment or u might go too far and f%(k it up
u mean dremel out the hole on the banjo thingy so ill have more room to work with and it might fit?
its coo. anyway....can i change the line with the turbo on the car? or i needa to take it out again, because if i do that would be even more pain in the ass.
Yes, you can change the oil feed line with the turbo on the car...... I did. :thumb:
AFAIK, it's a PITA to do this, at least on a 1G, because doesn't the oil feed line bolt to the rear of the turbo?
Yeah, the stock line does. I was refering to the stainless lines that you get from SlowBoy, RRE, etc.... They come in through the front. :thumb:
dammit...my line wont get here until december 1st!!! i guess ima try to swap the 14b's stock oil feed line onto the 16g to see if itll fit better..and if it does, ill jus leave it on for now. if i do..then ill have to take out turbo huh...? :cry:
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
