-3an Oil Feed Line
95AWD6Bolt
504
Dec 2, 2006
South Jersey, New Jersey
Does anyone know where I can find a -3an oil feed line from the filter housing. I have checked some of the vendors with no luck. I would really like to get one.
do you just need the line or the fittings to go along for the turbo?
3AN line can be found almost anywhere on the internet already cut to prelength with ends.
The fitting will depend on what turbo you are running.
If its from the oil filter housing then you need a 3/8 BSPT to a -3an. I know everywhere says 3/8 npt, but the npt is not an exact fit. You can always tap the threads with a 3/8 npt so it fits better.
-Goodluck
