v8s_are_slow
- 2,825
- 280
- Sep 30, 2002
Panama City,
Florida
Tried starting the car today after finishing everything up. Timing was WAY off and ran as if it were missing. Everything in it is new. Motor, tranny, etc. etc. Not sure if it'd be a problem with one of my MAFTpro settings or an ecu problem maybe?
It's a 94 car and using a 91 ecu. The 94 ecu was an eprom ecu, the 91 that's in it now isn't. Could this be it? Tried changing the CAS, and even tried turning it 180 degrees out. Changed plug firing order, grounded the timing plug, checked all the pro settings. Speed Density, IAT, AEM wideband. Mods are 2.3 liter, T-67 turbo, Comp 101400 cams, Built head with 1mm oversized valves, 1000cc injectors, AEM FPR set at 43.5 psi with hose off, SMIM intake, bored throttle body, etc. etc. etc. The timing light picks up the mark on the bottom side of the crank pulley
