1g DSMLINK with MAFTPRO
NJdsmguru
153
Oct 5, 2003
lindenwold, New Jersey
Does anyone know if it's possible to run dsmlink with maft pro.Using DSMLINK for fine tuning and it's features such as antilag,tps adjustment for my 75mm ford tb,timing adjustment etc.And use the maft pro for speed density and boost control. Are the compatible?
I don't see why not, but it seems like a huge waste of money. Boost controllers can be had for $100 in the classifieds and speed density isn't going to make that much of a difference. I don't think it's worth the $400 to only use it for those two things.
Yes it does, the MAF-T Pro sends a MAF signal, just as the MAF-T does.
i thought it would be compatible. i just wish i had the extra funds for aem ems so i don't have all this extra bs
AEM is overrated. I would just get Dsmlink and tune with that, the next version of Dsmlink might have speed density. They've been talking about if for a while.
GVR4592 said:
...the next version of Dsmlink might have speed density.
There are no plans for speed density, but they will allow you to run a GM MAF without use of a translator. Theres still a lot of things to be worked out, so its not coming out in the NEAR future.
Go back and read the thread on the Dsmlink forums again. They clearly state that speed density is as much of a possibilty as direct GM maf support.
