new motor low oil pressure
b00stAdict
101
Jan 22, 2009
broomfield, Colorado
im sure this has been answer multiple times and i HAVE researched for hours but i haven't got the answer im looking for as my situation is a little different.
So i have a BRAND NEW MOTOR, new bearings (main and rod) new pistons, new rings, polished cranks, bored .030 over. rebuilt head (stock rebuild with 3g revised lifters), new oil pump, bs eliminator kit, oil filter housing IS ported, arp head studs, ported 2g ex manifold, NEW Big 16g turbo, polished o2 housing w/ external dump stage 4 pressure plate w/ unsprung 6 puck disk, 3" turbo back exhaust w/ greddy muffler... i think thats about it i might be forgetting something.. but i got the main stuff.
Either way i have about 1200 miles on everything and my STOCK oil pressure gauge reads low but not all the way to the left but my AFTER market gauge reads near zero after its at normal operating temps.. literally at zero sometimes.
While cruising in 5th gear at 3k rpms its near 60ish psi, 4th gear at 5k rpms its near 80-100psi depending on wot or not. using 10w30 NON synthetic right now as i've only got 1200 miles on the motor.
Im just curious if this is normal or if i should be worried... :confused: do i have a faulty gauge? my wires are connected well to the gauge so i know its not that.
It runs PERFECTLY, runs smooth as can be, im only at 10psi right now because i haven't got around to installing my eprom ecu, maf-t, and injectors, along with my fuel pump and re-wire. im waiting to get 3k miles on the motor to be on the safe side.
so any suggestions would be greatly appreciated! :thumb:
Well being that this thread seems un resolved, I'll try an spice it up.
I have a rebuilt 6 bolt, .20 over, BS eliminator, built by English racing. It was stored for 4yrs. Until resent. I got what appears to be 0psi at idle when warm. I'm using a mechanical oil gauge, an have tried a different one to check accuracy. It's tapped into oil filter house (the front facing type with no oil cooler. I haven't driven the car yet, buy the oil pressure does rise quickly with throttle. I've ran 10w30 & 20w50 an no difference. I believe the oil port in head was ported. There is very little, to no lifter tick. Yep, there it is.. Help !!
