new delta cams, fresh engine, check engine light on...
jjrock5
1,854
15
Mar 19, 2006
Around, Connecticut
Well I finally finished the build on my 97 GST, quick summary, evo 3 intake, ported everything, newly added 3 in turbo back, and Delta 272/264 REGROUND cams, new stock bottom end, FPT28. I started the car up this morning for the first time without hestitation. The car runs pretty loud with the cat-delete downpipe. It idles slightly rough but I think that may be because of the TPS not being adjusted properly since I also did the 1g TB swap during the build.
My real question is, I get a cam sensor failure code (I think its code PO142 or in the 140s) and Im not sure if its because I have 'aftermarket' cams, do you guys think this is the reason? Im also assuming this could also be a reason for the roughish idle. I have a 97-99 cam sensor btw. Thanks for reading.
