New Clutch Slipping
lucid15
527
Oct 10, 2008
Portland, Oregon
I just finished installing my Fidanza 3.2 clutch kit, and lightweight flywheel. Im about 100 miles into the break-in process, and was reading the instructions where it says on the second test drive you should check for clutch slippage while going up a hill and fully depressing the accelerator. I did this and found the clutch slipping pretty bad. Should i be concerned or is this normal while the clutch is still being broken in?
have you tried adusting the clutch pedal this will adjust where it engages and disengages there is a vfaq or tutorial around here somewhere if you are not familiar with this and did you bleed the clutch
yes the one inside the car. i adjusted it to where it is now. i Also noticed that the pedal stops before it actually touches the ground. Which way do i rotate the rod now?
