ANGELRAY
89
7
Jan 29, 2024
Lubbock, Texas
I was wondering if all the things I need to build a new engine are in this here. I wanna build or attempt to build a 600+ hp engine. And if there's something I'm missing or if things won't fit.
πŸ—“οΈ MONTH-BY-MONTH PURCHASE PLAN (WITH LINKS)​
(Budget-optimized, realistic, no re-buying parts)
πŸ”΄ MONTH 1 β€” ENGINE FOUNDATION (DO NOT SKIP)​
Goal: Ensure all necessary components are in place for safe motor installation.
Buy:​
Engine Block Bare 4G63T 6bolt OEM 85mm bore
πŸ”—https://performancepartout.com/engine-block-bare-4g63t-6bolt-oem-85mm-bore/
Full Gasket Set Head Bolts Fit Mitsubishi Dodge Eagle Turbo 1st GEN 4G63 4G63T
πŸ”—https://www.ebay.com/itm/2206709213...ujcXS33X3X3pz2SxM6X2R11a8Q==|tkp:BFBM8uXV1uRm
ARP Head Stud Kit
πŸ”—https://arp-bolts.com/kits/product.php?PL=29&Set1_page=11
OEM Mitsubishi Oil Pump (NEW)
πŸ”—https://stmtuned.com/products/opmb1096-acl-6bolt-dsm-oil-pump
Oil Cooler Kit (Setrab core – budget & reliable)
πŸ”—https://www.extremepsi.com/store/Extreme-PSI-Oil-Cooler-Kit-Mitsubishi-Eclipse-6-Bolt-SALE.html
King Engine 6 Bolt Rod Bearings Mitsubishi 4G63/4G64 6 Bolt 1st Gen DSM
πŸ”—https://jdmuscleusa.com/products/ki...QTvoEixDjKvCWCFTDmOujXbStth-7VNLkVe9ud1jLVjjQ
Rods and piston 86.0 mm
πŸ”—https://www.eaglerod.com/item/5523515-4340-rod-mitsubishi4g63-4?category=293800
πŸ”—https://www.jepistons.com/product/j...iston-kit-85-00-mm-bore-1-130-in-ch-21-70-cc/
JE 4G63 6-Bolt DSM Piston Rings
πŸ”—https://stmtuned.com/products/je-4g63-6-bolt-dsm-piston-rings?variant=45961501449
ARP Main Studs for 4G63 Evo/DSM (207-5401)
πŸ”—https://stmtuned.com/products/207-5401-arp-main-studs-4g63-evo-dsm?_pos=1&_sid=c6511b321&_ss=r
Gates Economy Complete Timing Belt Kit with Water Pump: 90-92 Mitsubishi Eclipse 6-Bolt #28040
πŸ”—https://www.extremepsi.com/store/Ga...Belt-Kit-90-92-Mitsubishi-Eclipse-6-Bolt.html
STM Balance Shaft Removal / Delete Kit for 4G63 Evo DSM
πŸ”—https://stmtuned.com/products/stm-4g63-balance-shaft-removal-kit
Eagle Forged Crankshaft for 4G63 6-Bolt DSM
πŸ”—https://stmtuned.com/products/eagle-crank-4g63-6bolt-dsm?variant=40356604105
TOTAL ESTIMATE ~$3,520–$4,680+ (parts only)
🟠 MONTH 2 β€” FUEL & ECU SAFETY​
Goal: Make sure the motor can NEVER go lean.
Buy:​
Injector Dynamics ID1300x Injectors
πŸ”— https://www.maperformance.com/products/injector-dynamics-1300cc-injectors-dsm-evo-3-9-1300-60-11-d-4
Walbro 450 LPH Fuel Pump (F90000274)
πŸ”—https://stmtuned.com/products/walbr...6n_kbGv0UyZwLN5Mzc3gCSg4EzszPNDU1WLYJdVWga4MD
Adjustable Fuel Pressure Regulator (Aeromotive)
πŸ”—https://stmtuned.com/products/aerom...ure-regulator-6an?_pos=2&_sid=d4b4f73e2&_ss=r
GM Open-Element IAT Sensor Kit
πŸ”—https://stmtuned.com/products/stm-u...Ed2HMaRghOsYp981Hf7HGXKkwnaz6wUq8Op3Qt-VzUFHx
OEM Mitsubishi Knock Sensor
πŸ”—https://www.rockauto.com/en/catalog...ust+&+emission,knock+/+detonation+sensor,5108 ( wire the connector for the DSM)
TOTAL ESTIMATE ~$1,392.18
🟑 MONTH 3 β€” TURBO SYSTEM​
Goal: Bolt-on power hardware once fueling is ready.
Buy:​
FP GREEN for DSM
πŸ”— https://www.forcedperformance.shop/products/fp-green-for-dsm
STM 1G/2G DSM 6-Bolt Standard Placement T3 Exhaust Manifold
πŸ”—https://stmtuned.com/products/stm-dsm-t3-turbo-exhaust-manifold
TiAL MVR 44mm Wastegate
πŸ”— https://tialsport-outlet.com/products/tialsport-mvr-wastegate-see-options
ETS Race Intercooler for 1G DSM
πŸ”—https://stmtuned.com/products/ets-1g-dsm-fmic-intercooler?variant=32690560794709
TOTAL ESTIMATE -$4,188.85
🟒 MONTH 4 β€” INTAKE, CLUTCH, CONTROL​
Goal: Make the car drivable and controllable.
Buy:​
MITSUBISHI 4G63 VR4 DSM G1 BILLET INTAKE MANIFOLD (optional 4 injectors)
πŸ”—https://www.cncinnovationsmy.com/pr...cymNyCr3IO3bIPo9rmtMVUsbBp-HaHlGd7i72cp5k9ibZ
ACT HD Single Disc Clutch
πŸ”—https://www.advancedclutch.com/prod...xtg6-act-extreme-race-sprung-6-pad-clutch-kit
MAC 3-Port Boost Control Solenoid
πŸ”—https://www.full-race.com/3-port-ma...5HhAQ0RAc6NMBKekYjTbS_16SKBBe1XV68G8q4kZ94uH7
AEM UEGO Wideband Oβ‚‚ Gauge
πŸ”—https://www.aemelectronics.com/prod...ideband_gauges/classic_wideband/parts/30-4110
TOTAL ESTIMATE -$1,437.94
πŸ”΅ MONTH 5 β€” COOLING, BREATHER, TUNE​
Goal: Long-term reliability.
Buy:
Mishimoto Aluminum Radiator for 1G DSM (MMRAD-ECL-90)
πŸ”—https://stmtuned.com/products/mmrad...rad-ecl-90-mishimoto-1g-dsm-aluminum-radiator
Torque Solution 1G AWD DSM Rear Engine Mount (TS-1G-003) πŸ”—https://stmtuned.com/products/ts-1g-003-torque-solution-1g-awd-dsm-rear-engine-mount
Dyno Tune – ECMLink (97 octane)
πŸ”— Local ECMLink-certified tuner
TOTAL ESTIMATE - $418.95
🟣MONTH 6 β€” Head Build​
GSC Billet Cams for DSM
πŸ”—https://stmtuned.com/products/gsc-power-division-dsm-billet-camshafts?variant=646120833033
HKS Purple Cam Gears for 4G63 Evo/DSM
πŸ”—https://stmtuned.com/products/22004-am001-hks-4g63-purple-cam-gears-evo-dsm
ARP 4G63 Cam Gear Bolts for Evo/DSM (107-1002)
πŸ”—https://stmtuned.com/products/107-1002-arp-4g63-cam-gear-bolts-dsm-evo
GSC 4G63 Evo DSM Intake& Exhaust Valves
πŸ”—https://stmtuned.com/products/gsc-4g63-evo-dsm-valves-exhaust
πŸ”—https://stmtuned.com/products/gsc-4g63-evo-dsm-valves-intake
Topline Revised Lifters for 4G63 6G72
πŸ”—https://stmtuned.com/products/topline-revised-lifters-4g63-6g72
Mitsubishi OEM Rocker Arms for 4G63 6G72 (MD375091)
https://stmtuned.com/products/oem-mitsubishi-rocker-arm-4g63-6g72
Manley Valve Locks for 4G63 Evo DSM (13016-8)
https://stmtuned.com/products/manley-4g63-dsm-evo-valve-locks
Supertech Dual Valve Spring Kit for 4G63 Evo/DSM
https://stmtuned.com/products/m1007d-supertech-dual-valve-springs-4g63-evo-dsm?variant=37389739721
TOTAL ESTIMATE- $1,999.84
πŸ› οΈ LABOR TIME ESTIMATE (REALISTIC)​
JobHours
Engine R&R + accessories18–25
Fuel system + wiring4–6
Turbo kit install10–14
Intercooler piping4–6
Clutch install6–8
Sensors/boost control2–3
Cooling system2–3
Dyno tuning3–5
TOTAL49–70 hrs
πŸ”§ REALISTIC FINAL BUILD COST (Honest Range)​
When those missing items are added at the current market value:
➑️ LOW end: ~$16,800
➑️ HIGH end: ~$19,200
MonthPartBase Price ($)Estimated Shipping ($)Sales Tax ($)Total Cost ($)
Month 1Engine Block Bare 4G63T2509020.62360.62
Month 1King Rod Bearings5784.769.7
Month 1Gates Timing Belt Kit2992024.67343.67
Month 1JE Piston Rings172.881014.26197.14
Month 1Eagle Forged Crankshaft869.953571.77976.72
Month 2ID1300x Injectors955.51578.831049.33
Month 2Walbro 450 Fuel Pump154.991012.79177.78
Month 2Aeromotive FPR189.951015.67215.62
Month 2GM IAT Sensor49.9554.1259.07
Month 2OEM Knock Sensor41.7953.4550.24
Month 3FP Green Turbo224945185.542479.54
Month 3STM T3 Exhaust Manifold399.952533457.95
Month 3TiAL MVR Wastegate489.951540.42545.37
Month 3ETS Race Intercooler1049.954086.621176.57
Month 4CNC Intake Manifold4993041.17570.17
Month 4ACT Clutch Kit5893048.59667.59
Month 4MAC Boost Solenoid159.95813.2181.15
Month 4AEM Wideband189.991015.67215.66
Month 5Mishimoto Radiator2993524.67358.67
Month 5Torque Solution Rear Mount119.95109.9139.85
Month 6GSC Billet Cams6992057.67776.67
Month 6HKS Cam Gears3291527.14371.14
Month 6ARP Cam Gear Bolts54.9954.5464.53
Month 6GSC Intake Valves1891015.59214.59
Month 6GSC Exhaust Valves1891015.59214.59
Month 6Topline Lifters129.951010.72150.67
Month 6OEM Rocker Arms99.95108.25118.2
Month 6Manley Valve Locks59.9554.9569.9
Month 6Supertech Dual Springs2491520.54284.54
12557.2412557.2412557.24
Buy:​
πŸ”—https://www.ebay.com/itm/220670921393?fits=Year:1990|Engine+-+Liter_Display:2.0L|Trim:GSX+Hatchback+2-Door|Model:Eclipse|Make:Mitsubishi|Submodel:GSX|Engine:2.0L+1997CC+122Cu.+In.+l4+GAS+DOHC+Turbocharged&_skw=Gasket+Kits&itmmeta=01KCJPNEBF0AKREXJC5FAYHJBT&hash=item3361030ab1:g:31YAAOSwk4JlSrjf&itmprp=enc:AQAKAAABIFkggFvd1GGDu0w3yXCmi1eMrepIV3s8zWUuD8TfCUX3kFqgjTFvB44Aa9/hdWocpwKEtYM3qO0c3JWG19tMRvrDtq5/UDtR0APoDj/SGsYWJAVe+2eeGgqd1pSRikpBWYpG6bQnVE2/JRYZIiNADZm7ftp3Llqtp0JiRTQaBIwSLpnNL4mjaaSEdzR5t4l91TbPuSDJieFt+rYwET1ubC61PqtkI99HVrH+7fi+aKDBCzgXVhUOCnAougfvreP+cexjLprEH8rifF6S5bWK5wzHf04H10KsTOKhfQ/qbpENxDqI++w8N48FdAmmrdVx4wr0C0iYQOxilDprLpIz2c9kNuhgaEH04Yr0ZWGrujcXS33X3X3pz2SxM6X2R11a8Q==|tkp:BFBM8uXV1uRm
Do not buy an ebay gasket set.
discontinued. You'll have to look hard.
Why are you overboriing 1mm on an 85mm block?
No. Buy better belts and pump.
Buy:​
Buy:​
FP GREEN for DSM
600hp? Unlikely
t3? FP green is a standard DSM flange.
Buy:​
Buy:
Mishimoto Aluminum Radiator for 1G DSM (MMRAD-ECL-90)​
JobHours
Clutch install6–8
Cooling system2–3
Dyno tuning3–5
TOTAL49–70 hrs
building a fast car is SOOO much more than a collection of parts. Everybody seems to want 600 as if it's very easy or practical. Walk before you run. Get the car running perfectly and repair old stuff. There will be a lot of work before you even GET to go fast stuff. Transmission will be the weak link and we are a decade past parts availability.
You are welcome to use this Cost Analysis Spreadsheet.
Getting harder to find but they are still out there. I was trying to save the stock bore block that came with the Grey Racecar but ended up having to bore it to get rid of some rust pitting my hone wouldn't take out :(
    Early Mitsubishi logo valvecover. β€œ1990” All threaded holes are good. Has the 90 style vent...
