new build ?
iluvmy4g63
216
Apr 7, 2007
baltimore, Maryland
well here's the ? I started a new 4g63 2.0 build for the old conquest that my cousin has had sitting around for 5 years now. (with shot motor) the block i have has had 2 thousands of an inch decked from block and has had 3 thousands from the head milled. to get both perfectly flat. the ? is with that much removed from block and head is there going to be a piston to deck problem? we have not bought any internals yet. please help out with some do's and don'ts with this short block. i do have a set of eagle 150mm rods that i would like to use on this build. and most likely a set of ross pistons( hey my cousin is paying for the pistons so iam not going to argue with his choice) if there is a clearance issue, can a extra thick head gasket help? is there away to find out before a piston purchase. :confused:
note its a real low budget build. and most of the parts are going to be used except pistons,bearings,T/B stuff. is there a math formula to help me find out the rod to crank ratio? or would i have to do the clay test?
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
