neon cam
al3xxx
Jan 11, 2011
valcourt, QC, Canada
hello i want to know if neon cam fit on my eagle talon esi 95
beacause i try it but my motor don't start and they tell me code 43 misfier
tanks for help me
and scuse me my englis is very very bad
yes it was in the motor
i take te cam for a neon 98 doch
No, they're not compatible. You need cams from another 2G N/T Eclipse, Talon or an I4 Avenger with the 420A engine.
why they're not compatible what its the différence
Possibly bent valves :ohdamn:
The Neon head has the reverse flow of the Eclipse head (basically the intake is on the front side of the engine and the exhaust is on the back side while our Eclipses have the exahsut on the front and the intake in the back). So you are putting the intake cam on the exhaust side of the head and the exhaust cam on the intake side of the head (along with timing differences on the cam gears).
If you were to put the Neon exhaust on the Eclipse exhaust you would have to account for timing changes and cam angle sensor movement.
More importantly right now, you should check for bent valves.
MB
maybe my valve are ok beacause my compresion are good i will check my compression whit the other cam to check if is the same
tkans for help me
tkans for help me
That's a good sign. Put the Eclipse cams back in.
Out of curiousity, why did you try the Neon cams in the first place? Were they aftermarket cams?
MB
because when I take my cam pulleys i broke the little pine who is in the cam and cam and my friend have neon cam and i put them in my motor
sucse me for my bad english :p
this is a common mistake. Well, thinking that the neon and dsm engine are identicle. They are both chrysler and share alot in common; but like mentioned above the head is 180˚ out.
Hopefully there was not too much damage and good luck!
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
